Hi, all!
Strange problem.. It's so simple in Maya or Blender..
For example if I import human model from MakeHuman there are several continuity components (body, head, eyes etc.) in ONE geometry.
How can I select exactly one of these continuity components? (I mean to select all faces of the component.)
Thanks in advance.
How to select continuity component?
11487 5 1-
- Buddha
- 12 posts
- Pagefan
- 519 posts
- digitallysane
- 1192 posts
I don't know what “continuity components” means, but I suppose you're talking about groups of polygons (groups of primitive in Houdini) and groups of points.
In the component selection menu you have the options to select Primitive Groups and Point Groups. You click a poly and the whole group is selected.
See here http://www.sidefx.com/docs/houdini9.1/basics/select [sidefx.com]
- Buddha
- 12 posts
- Buddha
- 12 posts
digitallysaneI mean http://en.wikipedia.org/wiki/Connected_component [en.wikipedia.org] I just didn't know correct english term for it.
digitallysaneIn fact I tried it and it selects only separate faces (in my case).
- digitallysane
- 1192 posts
BuddhaThis means there are no groups of primitives. If select connected works in you case, it means your geometry contains several meshes.
However, you can have one continuous mesh and on it you can define several groups of primitives on it (with the Group SOP for example).
You can then select those groups with the Primitive Groups option in the select menu.
Dragos
