Now I am trying to set some control for rigging a character with a few nulls. Does anyone know how I can set some translation limit for the null?(e.g. maxValue =3, minValue =-3) I tried to edit the parameter interface but I could not have done it successfully.
In the previous version of Houdini, I remember that there were a function called subnetwork. It is for simplfy a complicated network. But I cannot find it in Houdini 9.1 Does anyone know how we could simplfy a complicated network in Houdini 9.1
Any help will be appreciated! thanks!
set some limit
3752 5 1- brucelay
- 313 posts
- havana
- 67 posts
- andrewlowell
- 537 posts
- brucelay
- 313 posts
- andrewlowell
- 537 posts
- AdamJ
- 268 posts
If you have animation in your parameter clamp will work (LMB click on parameter to switch between value/function).
clamp(bezier(),-3,3)
Unfortunately you can only do this once you have keyed the parameter. If there's no animation data this will not work.
If the parameter is promoted to top level of digital asset you can set limits on it in the type properties window using the ‘range’ toggle.
