Q : Viewport operation
How can I change viewport angle ,when I select and modify geometry.
I could 2step method. push s-key and modify geometry then push Esc-key and thumble.
I'd like to 1step operation like a maya style.
Q: pivot operation
I'd like to move the selected polygon mesh in the direction of the normal.
houdini UI operation
11640 5 2-
- gundam
- 11 posts
- symek
- 1390 posts
Strongly advice you to see *all video tutorials from Tutorials section and Apprentice Blog section on this site… you will give yourself some peace.
Q1: Press Space bar to break temporary any viewport tool.
Q2: You move pivot with the same key as in Maya -> ‘ (check out Maya transition Guide" in Houdini’s Introductory (menu Help -> Start Here).
I don't think you can align pivot to prim's normal in EditSOP. This is doable via PeakSOP though. I could be wrong I'm not a modeling monkey, sorry.
EDIT: EditSOP has a second mode (see its tabs), called Peak. Switch to this tab and your handle will align to normal of selection.
sy.
sy.
- gundam
- 11 posts
- probbins
- 1145 posts
This sounds like an OS desktop setting. Are you on windows or linux?
You'll have to check your desktop settings and re-assign you Alt key there.
gundam
Thank you.
but I could not change to hot-key assign to Alt-key(maya style).
and I'll check to video.
“everything is coincident”
- old_school
- 2540 posts
- gundam
- 11 posts
