Application hangs on exit - Ubuntu 7.04
   10490   4   0
I have installed 9.1 Build 124 on a Toshiba Laptop running Ubuntu 7.04.
The installed graphics card is an ATI Mobility Radeon 9000.
I know it's a very low end machine but it's either that or a PowerBook G4.
I have set HOUDINI_OGL_SOFTWARE=1 to get Houdini running.
I noticed that as Houdini is running, I see the following on my console
Any suggestion?
I am mainly learning about the SDK and possibly can run Houdini in console mode to test output the plugins I write. But there will be occasion where the plug-ins are more visual and I need the interactive display.
8<——8<——8<——8<——8<——8<——8<——8<——
X11 Error (155): GLXBadContext
x11_ErrorHandler(_XDisplay*, XErrorEvent*) (X11_GeneratorThread.C:0)
_XError (??:0)
_XReply (??:0)
glXMakeCurrent (??:0)
RE_XServer::GLMakeCurrent(unsigned long, void*) (??:0)
Regards
Nicholas Yue
HOUDINI_OGL_SOFTWARE is only available on Windows.
I did not know that. Perhaps the hconfig help should reflect this?
J.C.
John Coldrick
Done.
Switching to KDE solves the problem of the application hanging on exit.
http://www.psychocats.net/ubuntu/kde [psychocats.net]
Gnome does not play well with Houdini.
Apparently with other 3D applications too e.g. Maya. so much so that it was discuss on the Autodesk forum.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=posting&mode=quote&p=54278 [sidefx.com]
Regards
Nicholas Yue
