Initialising Houdini, The console shows me this message:
Warning: OpenGL shader extensions not available.
This is a limitation of your video card
or driver, and will prevent Houdini from
using GLSL shaders.
Set the HOUDINI_OGL_ENABLE_SHADERS
environment variable to zero to avoid
attempts to use this extension.
Where could I change the enviroment variables??
Disabling HOUDINI_OGL_ENABLE_SHADERS
11739 5 0-
- MAN9A
- 43 posts
- anon_user_62699880
- 1 posts
right click on “my computer” > last option “ properties” > “advanced”> “environment variables” > in system variable or user variable ,press “new” to make a variable > fill the name with :“ HOUDINI_OGL_ENABLE_SHADERS” . fill the value “ 0 ” . save and everything ok .
if possible , get a better video card . maybe u video card is a on board card .
- edward
- 8161 posts
It would also help if you save out the diagnostic information from glview and attach it in this forum.
http://www.realtech-vr.com/glview/ [realtech-vr.com]
- Mikas
- 11 posts
I have the same problem. My graphics card is NVidia Quadro FX 3500. It is 100% compatible with OGL 2.1. But it is not compatible with OGL 3.0 or 3.1. Could it be the reason?
Mikas Sadauskas
http://vfx.miko.lt [vfx.miko.lt]
- edward
- 8161 posts
- Mikas
- 11 posts
I seems that I found a reason: there was Adobe After Effects CS4 running in background and that caused the problem. It seems that AE CS4 occupies OpenGL's resources very aggressively.
Mikas Sadauskas
