Heys guys Ive hit another issue with multiparms in a custom Mantra Digital asset ive built.
When I create My HDA and I bring up the mantra “extra image planes” to my HDA interface, and add my image planes as usual. It Looks to work fine, but when i render, my extra image planes dont output at all. I basicaly can only see the main colour image in mplay.
To fix this issue, I have to dive into the digital asset and jump back up again to cook the interface changes. I then can render and my image planes appear as expected.
I tried using the opcook command but this returns an incorrect opengl driver version error.
So I used pythons hou.Node.cook but this doesnt make a difference. I still need to dive into the HDA to update the imageplanes.
so part of my script that helps with the HDA interface I have this code.
root=hou.pwd()
hou.node(root.path()+'/mantra1').cook()
So I guess my three questions are.
1. Why doesnt my HDA interface update the mantra1 node inside it when I edit the the Multiparm for extra image planes?
2. My self and most others here are getting this wrong opengl driver issues with specfic commands, a good example is the layoutnode commands in python and hscript.
3. If im using
root=hou.pwd()
Why doesnt this cook my mantra nodes interface changes?
Im using houdini 9.1.145 on windows xp 64bit
Nick
Mantra HDA problems and incorrect opengl driver
3245 1 1- niko3d
- 338 posts
- niko3d
- 338 posts
In regards to extra image planes on mantra digital asset, there does seem to be a bug where they arent propergated from the interface to teh mantra node.
I was given a work around to the bug from support. I was using opcook before which doesnt do anything on a rop network, as nothing cooks as such. So instead to force my mantra node to pick up the extra image planes intial change I was told to use.
root=hou.pwd()
hou.node(root.path()+'/mantra1').parmTuple(“vm_numaux”).eval()
This solves the problem thankfully :¬)
Opengl errors when running certain commands I think are nvidia geforce win 64bit driver problems?? has anyone solved this without changing to a quadro?
Cheers
Nick
root=hou.pwd()
Cheers
Nick
