I exported obj and fbx of my geometry from maya. When I import it into houdini 9.1.179, the obj has bad normal(some normal is fliped and some isn't), the FBX has bad UV……anyone knows what's wrong with it?
Though I use transfrom sop to make the geometry looks right, but the normal is not right. when I attach it to fur sop, some fur is long and some is short. When I use fbx, the fur is right, but the uv is not right…..-.-!
thanks for any anwser.
normal problem of obj and uv problem of fbx
4001 3 0- ykcosmo
- 288 posts
- ykcosmo
- 288 posts
- oleg
- 350 posts
ykcosmoThe UV import bug was fixed in FBX code as of 9.1.180 - you're just one build short of the correct version.
If you still need it, you can download the latest build and give it a try. It should work.
Oleg Samus
Software Developer
Side Effects Software Inc.
Software Developer
- ykcosmo
- 288 posts
