If I set up soem particles using the particle SOP, my particles get a $ID attribute. Why can't I use this attribute in an expression?
I.e. If I put rand($ID) into one of the fields on the particle SOP, it says it doesn't recognise the variable, even though each point has $ID…?
Why can't I use $ID when using the particle SOP
3701 4 0- jonnymorrisus
- 4 posts
- stevenong
- 1631 posts
The problem is the attribute is created at birth but the expression depends on the attribute being existant. It's a small distinction but that's the way it works. I could be wrong here.
What would you like to do with the expression? Also, any reason for not using POPs? Unless, of course, you're using Escape.
Cheers!
steven
Cheers!
steven
- jonnymorrisus
- 4 posts
Oh okay.
I tried to use it because I assumed the points get created, attributes initlalised and then forces get applied after that.
What I want to do is to use expressions like fit01(rand($ID+2342),5,10) in the forces tab of the particle sop to randomise forces between each particle.
I want to use the particle SOP as I want to use it in conjunction with metaballs and the force SOP to generate some weird directional and axial movements…
Thanks for your help btw!
- Gerome
- 85 posts
- jonnymorrisus
- 4 posts
