It's probably an old issue but i couldn't find a solution to it on the forum but when using tools from the shelf in Create in Context mode i always get this error.
File “sop_tube”, line 4, in <module>
File “toolutils.py”, line 528, in new_func
return function(*args, **kwargs)
File “soptoolutils.py”, line 540, in genericTool
merge_context)
File “soptoolutils.py”, line 346, in genericSopNodeGeneratorTool
pos = positions * container.worldTransform().inverted()
AttributeError: ‘SopNode’ object has no attribute ‘worldTransform’
Laying down sops in network view works. Something which can be easily fixed or should i forget about using the shelf when in Create in context mode?
Error using shelftools when in Create in context mode
5916 2 1-
- Pagefan
- 519 posts
- old_school
- 2540 posts
Hi Pagefan,
Nope I do not get these errors and no this should work as my work flow depends on it.
Any details you can give us would help. See the sticky thread in the Technical forum about what to do when you've found a bug. Need the version of Houdini, OS, etc.
It might be a case of conflicting python libraries… Don't know.
- Pagefan
- 519 posts
