I have a .pic that passes bounding box colors to points on a grid.
I copy boxes to these points.
They are also being scaled and transformed based on how much red they have. (this video tut sound familiar?).
This works all very well.
This is an animating geometry since I'm reading in a series of .pic's.
I'd like the last .pic (copied boxes with scale, color, transform) to turn into particles and blow away.
I was thinking I could use DOPs (have been successful creating rose petals opening then falling off this way),
but it's too much processing since I have about 3000 boxes.
This thread's example is almost what I want to create, but I need to retain the copied geo (boxes).
Hope I've explained it well, keep in mind that I'm probably at the same level as Symbolic.
Copy SOP to POPs please
4649 5 3- massta
- 61 posts
- Allegro
- 696 posts
- massta
- 61 posts
- Allegro
- 696 posts
- massta
- 61 posts
I did look at your file. The POPnet Wind has an error trying to find the Group1.
I'm going to play around with this some more since I think adding the popnet before the copy sop is the right direction I need, then a switch sop to go between the still grid and particle grid, much like what you've created. Thanks.
Touch Designer User
- massta
- 61 posts
