H9.1.179
Win Vista64 SP1
Using COPs, let's say I have a series of images rendered from 100-1000. I want to blur frames 100-200 using the fit expression ( fit($F,100,200,0,5) ) … then repeat the same process on frames 350-450, 600-700.
I want to avoid having to chop this into chunks of frame ranges. Is there a COP that can do this? I'm sure there's an easy way of doing this :shock:
Thanks in advance,
Rob
*** posting this to od-force
COPs repeated process
3135 2 1- rdms
- 201 posts
- probbins
- 1145 posts
- Dean_19
- 319 posts
Use the modulus operator (%) to feed a repeating number range into your fit function rather than just the current frame number.
E.g. Instead of using something like:-
fit($F,0,100,0,50)
use:-
fit($F%100,0,100,0,50)
This will repeatedly ouput 0-50 over a range of 100 frames, i.e. 0-100,100-200 etc.
Or if you don't want it to be over a continuous range and have gaps, it a bit long winded, but you could do it with multiple if else statements, something like this:-
BLURMAX = 50;
BLURMIN = 0;
FRAMEMIN = 0;
FRAMEMAX = 0;
if ( $F > 100 && $F<201 ) {
FRAMEMIN = 100;
FRAMEMAX = 200;
}else if( $F > 349){
FRAMEMIN = 350;
FRAMEMAX = 450;
}else{
return 0;
returnme = fit($F,FRAMEMIN,FRAMEMAX,BLURMIN,BLURMAX);
return returnme;
In the blur amount (or whatever its called) parameter should work. There may be a more efficient way, but this way at least will work!
I'll try and post a hip file soon..
fit($F,0,100,0,50)
use:-
BLURMAX = 50;
BLURMIN = 0;
FRAMEMIN = 0;
FRAMEMAX = 0;
FRAMEMIN = 100;
FRAMEMAX = 200;
FRAMEMIN = 350;
FRAMEMAX = 450;
}else{
return 0;
return returnme;
