In the help it says
“Each channel can be shifted a different amount by using the $C variable in the Scroll parameter or the Start/End parameters.”
Just tried this, $C works in the scroll parameter, but not in the start/end parameters (all channels get shifted by the same amount), which is what I am interested in.
Is there something I understood wrong? any workaround ?
Using H9.244.
Thanks a lot.
edit : tried using the expression CHOP with ic(0,$C, $I-5*$C), but I get the same result as with the scroll parameter (the values get shifted but not the range), I don't know if it's possible to actually shift channels with the expression chop.
$C variable in Shift CHOP only half works ?
6007 4 2- vinz
- 113 posts
- andrewlowell
- 537 posts
yeah I remember running into this issue. You could trim the CHOP to the maximum offset before hand, which could take some memory; or you could write a more complex expression in the expression CHOP by offsetting the variable $I.
There might be a cool way to use the $C in the other parameters as well.
- vinz
- 113 posts
- malexander
- 5167 posts
- vinz
- 113 posts
