When creating a fluid sim,I see in the scene level that a DOP network is created with a bunch of attributes for vel, density etc…
I can reference this information is a volume shader, so I get its adding an attribute that can be used.
1. Is this its only function?
2. Can I use these attributes to influence another RBD sim or something, how do you go about that?
3. Can I do similar things with POP nets and use Particle AGE attibutes within shaders etc…?
Sorry so many questions…so many Houdini discoveries still to make!
BTW, I really do appreciate all the help from this forum in learning Houdini - I would be in dark about so many things with it - many thanks!
DOPS, POPS and attributes - a question or three!
3438 3 1- stevecullum
- 112 posts
- stevecullum
- 112 posts
- graham
- 1908 posts
The problem is that you cannot merge data with objects. In order to apply the field force, you need to wire the rbd object steam into the field force. Also, I recommend you alter the input order of the merge so that the smoke solver is connected last. There was a bug fixed recently where the smoke object wasn't ordered correctly.
- stevecullum
- 112 posts
