cop image to shader?
   4998   2   0
I've brought an image into the compositor and lumakeyed the background out. The resulting image is then used in a trace sop to create a a spline, the outline of a leaf in this case.
I now want to take the image from the compositor and apply that to the leaf shaped surface.
How do I get the Cop image into a shader?
“everything is coincident”
I believe you can use the “opimg/img1/cop_node” syntax as the value to a string parameter which feeds into Texture Map VOP.
This is a great feature!
I'd love to see that little “+” button on the side of the image fields support a tree view to select from COPs.
Jason
