when i use “$LIFE%0.2==0.1” as rule to create Group,then put it into split pop to emitter particles. but the group doesn't work,why?
if i use above rule to create an popevent ,but any affect can't be seen still.
why?
questions about GroupPOP and eventPoP
3119 3 0- flyingc
- 160 posts
- flyingc
- 160 posts
- curveU
- 4 posts
hi, my understanding is that there are no states matching the condition of “$LIFE%0.2==0.1”. Due to the limited sampling rate, the situation may be at one frame $LIFE%0.2< 0.1 and then at the next frame > 0.1. I guess you want to achieve the effect to split particles every certain frames. Maybe use “$FF%24 == 1” instead?
Hope it helps.
Hope it helps.
flyingc
why?
- flyingc
- 160 posts
curveU
Hope it helps.
Thank you .
i think i have found the reason.
that is ,like you said,the value renturned from $LIFE%0.2 is never equals to 0.1 because the data type is float.
so ,i use round() function to convert it to integer type ,then it works.
(round($LIFE*100))%20==0
