I have add a SOP_Node::primGroupMenu to my SOP and its all working as it should. Then I tried to use some finished script calls (or what they might be called) such as ‘$F’ which should be the current frame in Houdini.
But when I use $F all I get is 1, no matter what I change the current frame to.
So I wonder, is this function automatic, meaning that the function will send in the Current Frame into my SOP, or will I have to manually calculate the current frame myself?
I have to work with group names manually, and if the user adds ex. 5-1 as input. But do I also have to do it manually if the input is a Houdini function?
Use functions such as "$F" in a SOP function
2552 3 1- CodeMasterMike
- 26 posts
- Allegro
- 696 posts
- CodeMasterMike
- 26 posts
- Allegro
- 696 posts
