menu script
   4464   3   0
Ok, my hscript knowledge are near zero so I need a little bit of help.
I have an HDA with a menu item (a list: token->a string, label… ).
I need to generate another list ( in a menu ) based on the choice of the first.
Something like this:
result = “”
if my param value == someString
result = token…label…token…label
else if my param value == anotherString
return result
So it would be cool if someone could give me the correct syntax for the menu script.
I don't use Houdini a lot at the moment
Tky.
I could be wrong but…
I don't think this is possible - since the menus are a part of the definition and therefore can't be dynamically built…
Training Lead
www.sidefx.com
Look in the help of the type properties. Yes, you can define dynamic menus.
should be…
if (`ch(“param”)` == 1 ) then
set list = ‘billy billy’
else
set list = ‘joe joe’
endif
echo $list
heh, it's been a while since I've looked at the if() syntax, but gives you the idea
