hi all,
i'm exploring the meshing pattern, since all the lines are straight in a polygon meshing, is there any way to select individual lines to make it as a curve? i tried to isolate the edge and make it polyspline, however i cannot merge it back to the original surface to be part of the primitive divisions. Please see here-
http://farm4.static.flickr.com/3275/266741…ecd4d2426_o.jpg [farm4.static.flickr.com]
thanks
meshing pattern
2211 2 1- herman02
- 22 posts
- herman02
- 22 posts
- Simon
- 2199 posts
Not without introducing a whole load more points and triangles to join those points back to the others in the geometry.
To do so you would have to blast out that row of polys that the line intersects then build your curve and extract the edges of the other polys and polyloft the curve and the extracted edges together and finally merge and fuse the result
