Tif and Rat problems
   7248   7   0
Hey guys,
My main problem is i cannot use the tifs i want. It simply says “unable to load texture”.
You can see it isnt the backslash problem
Yet i can manually load it in mplay.
Is this a restriction, because the texture is high rez?
Also i know that using RAT files are more efficient so in an effort to use the iconvert method i come up against a brick wall.
“Can't create output file”
Is this another restriction of Apprentice?
Like I said I can manually load the tif into mplay, but when i save it out it squashes it (non-proportionately) and applies the watermark (which i though that only applies to final render, etc)
The thing is this is a displacement map, so will the iconvert apply a watermark and size the texture down? If so, then how do i use the original tiff because it simple wont load.
blog [abvfx.wordpress.com]tumblr [andrewbrowne.tumblr.com]twitter [twitter.com]
Yes, it's an apprentice restriction. Because houdini now creates .rat versions for all textures on the fly, the resolution restriction comes into play here. ie. none of your non .rat textures can be over the texture resolution restriction size. You'll also have to look out for the houdini logo watermark in the new .rat files as well.
cant argue with that.
I got the tifs working. (i was using an old build of Houdini).
does this apply to houdini HD? If not then i guess it is time to shell out for it.
That bug was fixed in 9.5.204 as I replied in the other forum. I really wish people would stop cross posting.
Let me re-iterate, there are NO resolution limits imposed on READING images, in any edition of Houdini.
sorry edward.
But stu says none of my rat textures can be over the texture resolution?
So if i had a 4k tif, and use it as a displacement, will mantra read it, convert it and resize along with applying the logo it at render time?
or will it just convert it to a rat?
stu's comment was due to a bug that has since been fixed. There are NO issues with using textures (of any size) for rendering. It will internally convert to .rat without changing the contents of the image. This thread should not have existed. It would have just worked as expected had the current production build of 9.5 been used.
“This thread should not have existed.”
Hear that everyone? No more posting questions that you don't already know the answer to. Thanks for clearing that up edward, I'll be sure to keep it in mind for the future.
well to be fair…I thought that Apprentice had a texture limitation of 512x512…
Training Lead
www.sidefx.com
