Hi
I would like to get the current viewport name
is there any hscript or python function that do the job?
I looked in the help but could not find anything
regards
get current viewport name
6356 4 1- Anonymous
- 678 posts
- graham
- 1906 posts
There are 2 similar ways of doing thing using python.
If you are trying to do it from a shelf context you can take advantage of the
'activepane' key in kwargs.
import toolutils
# This should return a hou.SceneViewer object if you have a viewport showing.
activepane = toolutils.activePane(kwargs)
name = activepane.name()
You can also do import toolutils
viewer = toolutils.sceneViewer()
name = viewer.name()
If you don't see something in the help, chances are there is an example of something happening in the scripts located in $HH/scripts/python/
toolutils.py in particular can be very useful for seeing examples of certain
things and how the tools are implemented.
import toolutils
- VisualCortexLab
- 509 posts
heya,
I'm working on a simple script here that would be a shelf tool.
I'm trying to figure out what type of node I'm supposed to grab from, let's say, the $HOUDINI_TEMP_DIR copied buffer.
I tried different approaches, all of which sort of failed eventually and now I'm into this one, getting the active pane and go from there.
problem is that if I create a shelf tool with the following code:
import toolutils
print name
If I have the script window opened I always get
<hou.Pane 5>
when if I close it (and have no floating panes) I get
panetab1
… no matter where my mouse has clicked last.. what am I doing wrong?
how can I get the network pane of the last mouse click?
(or what could be another approach)
import toolutils
print name
<hou.Pane 5>
panetab1
JcN
VisualCortexLab Ltd :: www.visualcortexlab.com
- VisualCortexLab
- 509 posts
toolutils.sceneViewer().pwd()
seems to give me a result closer to what I'd need …
but I'm still open to suggestions
thankie!
JcN
- VisualCortexLab
- 509 posts
sum][one
thankie!
scrap that. it does give me some output, but somehow is not related to what's in the network I'm using .. changing context of such pane doesn't change the output of that code..
i'm stuck again
JcN
