Projecting on Polys
   5601   4   0
I want to project a 2d L-System onto a polygonal object, but the project SOP won't work as is it polygonal, does anyone know a walkthrough to manage to project anyway ? I tried the convert SOP, to convert it to bezier or Nurbs surfaces, but I guess my poly cage is not clean enough to get a one surface conversion
Thanks in Advance
Julien
Use the Ray SOP. Remember to make sure you have normals that point in the direction you want to project.
yep ! it's working
Now I just have to find an expression to make the normal point in the direction I want …
Thanks !
Julien
You can't position your L-system so that it projects along one of the major axes?
my main problem is that it should project along multiple axis
