In Maya I know how to create an in view control that has limits on how far it can move.
IE a box that can only move a distance of 1 unit in the x direction could be used as a slider controlling a blend shape.
Or limited to one unit in x and y you could now control blends for an eyebrow, up/down and in and out.
by scaling a parent to these controls you you can control the size of the control without effecting the functionality
What I would like to know is how do I set limits like this on say a null, The standard control object?
Limiting range of motion
3856 3 1- anon_user_54555117
- 69 posts
- Simon
- 2199 posts
- probbins
- 1145 posts
Another, immediate, way to do this is to drag the parameters you want in to the 3d interface and make HUD sliders.
Then RMB on them and choose the Handle Parameters. You'll see you can lock to Low and High range and set those ranges to the values you want.
“everything is coincident”
- 69 posts
