Hi everyone,
Say I have a digital asset which has got a “Folder” Parameter of type “Multiparm List”. I have to reference it to a node inside the asset. The problem is everytime the number of elements in the list is not the same. Can someone tell me how to reference the multiparm list.?
Cheers.
Referencing Multiparm List
7008 7 3- Raavenish
- 52 posts
- Raavenish
- 52 posts
- koen
- 789 posts
- Raavenish
- 52 posts
Hi Koen,
Sorry for the late reply. Initially I was also using python. But you can also do it via edit parameter interface. Create a “multiparm list” for a node. Create another node and select “edit parameter interface” option. In that dialog box, Choose “From nodes” option and select the node which has the “multiparm list” and copy the folder onto your node. Now the node you created first will be refernced by the new node.
Try this out and this works for me.
once again sorry for the late reply and thanks a lot for your interest.
Cheers.
Cheers.
- rdg
- 401 posts
koen
There must be cleaner solution though. I would be interested in your solution.
not sure if this is cleaner, but that's what I usually do:
The number of avail multiparms is accessible via the folder name:
numparm = node.evalParm('mymutiparmfoldername')
for n in range(0, numparm):
print node.evalParm('parnname_%s' % n)
this is not a science fair.
- koen
- 789 posts
- oat
- 479 posts
Raavenish
Hi Koen,
Cheers.
Hi, I can't make it work as you suggested. I got warning that Node is outside subnet: /obj/geo1/null1/folder0.
Can you kindly post an example for your solution?
- pelos
- 617 posts
