What is the best way to create a single .sim file to be written to disk? I want to write a single frame to use as initial state in my AutoDopNetwork.
If I add a File Dop and hit play it seems like there is no clear indication when I have to stop the sim to be sure the .sim file is not being overwritten.
Run a simulation and find a good frame you want your initial state to be set to (as an example, say frame 100). and with a fileDOP attached to the network, step forward from frame 99 to 100, and it will write that single file out.
Now add that to the inital state slot on the dopnet container.
