I had just assumed this would be an easy thing to do but now I'm not sure its possible at all. I want to make shapes and use them as pumps for smoke so that the smoke will fill the container, I have tried with some poly objects I modeled that has a bend in the object but it seems the smoke won't pump through it… is this possible? maybe its something I did as I'm still fairly new to dynamics so I will keep trying to see if I can get it.
thanks for any input.
Possible to make a pump for smoke curved?
3297 3 0- rdane1010
- 120 posts
- stevenong
- 1631 posts
- rdane1010
- 120 posts
Thanks for the reply.. well here is an .obj file that I am trying to use as a pump.. I want to make it so that I can pump smoke or fluid through it but I can't get it to work, it just goes in a straight line so the liquid or smoke doesn't curve with the object.
http://in-house-work.s3.amazonaws.com/8-14-09/apump.obj [in-house-work.s3.amazonaws.com]
I'm using apprentice so I didnt post an .hip file.
thanks for any help anyone can offer.
- rdane1010
- 120 posts
