I am consistently receiving an error message after rendering a couple hundred of HD-size frames - see attached screenshoot.
I checked the file (IFD.py & IFD.pyc), I can access it easily, so not an access rights problem. I need to restart Houdini to continue rendering, re-rendering without restarting generates instantly the same error message.
I'm not sure whether this might be a memory issue (I have 4Gigs only, Win7 x64)? This has been persistent across at least 20 recent builds, not sure about earlier ones.
Thanks for all suggestions,
Greg
Rendering problem - a memory issue or a bug?
6309 7 1- aiworks
- 130 posts
- Soothsayer
- 861 posts
- Dageris
- 95 posts
HI, I am also having the same problem. Ive tried to figure out what causes it but no luck. All i can say is i seem to only have gotten it with particles in the scene. But that might or might not be the cause, or a contributing factor. I cant say for sure.
Ill try rendering scenes out without particles to see if i can still get the error or not.
- aiworks
- 130 posts
- Dageris
- 95 posts
Hi aiworks,
Thats good to know, that both of us seem to be having it pop up when we are in particle scenes. Wish i knew why that is, and the reason for it happening. Its starting to get a little annoying, rendering something out and having to start over, hoping it wont happen.
EDIT: looks like i just had it happen again, I cant seem to render over 500 frames without it happening. This is a particle scene with 1000 frames
- Soothsayer
- 861 posts
- Dageris
- 95 posts
- Soothsayer
- 861 posts
