I'm doing a sim with a volume fluid flowing into a container that brakes after a few frames.
So, I need to switch the geometry from RBD Object to RBD Glue Object at a certain frame but Houdini doesn't update that switching properly. If I simulate the objects separately it works but if I use a Switch DOP it fails, it simply behaves as if the second object didn't exist.
What is the workaround to this?
Edit: I also tried animating the internal glue value, but similar problem; it works as expected on separate settings but not when animated.
Switch in DOP not working properly
2395 2 0- Soothsayer
- 861 posts
- Infernalspawn
- 229 posts
- Soothsayer
- 861 posts
I think you are right, it has something to do with it.
Would I use that expression in the DOP context?
In the attached file I did a very simple setup and did the switch on the SOP level. As I said before, individually the switches work but if you animate the switch it doesn't. Since both objects have a different gemetry I wonder how to transfer those velocity attributes if I wanted to switch objects at say frame 10.
Jobless
Jobless
