Is this still possible? I found an old od video that mentions this. However I can't seem to get this to work in Houdini.
As I understand it, I should be able to re-align/re-orient the construction plane, and then be able to create new geometry, such as a box, so that the geo is in alignment with the c-plane. Is this still possible and if so, is there something special you need to do?
Create new geometry that's aligned to the construction plane
5868 7 1-
- jimc
- 295 posts
- ragupasta
- 349 posts
- jimc
- 295 posts
- edward
- 8051 posts
- jimc
- 295 posts
- edward
- 8051 posts
- jimc
- 295 posts
According to the video here (assuming it plays for you)
http://forums.odforce.net/index.php?/topic/56-movie-construction-plane-modeling/page__view__findpost__p__64368 [forums.odforce.net]
you used to be able to. I don't know what version of Houdini they're using the video, but they do show aligning the c-plane to a face, then creating a curve, with the CV's aligned to the c-plane. Sure would be nice if you could do this now.
- edward
- 8051 posts
Oh, you mean create *curves* on the cplane?
I can't view the .wmv file but here's a screencast using H10.0
http://screencast.com/t/NjZhN2NmMmE [screencast.com]
