why use .rat?
10291 7 3-
- Andrew Graham
- 151 posts
im just wondering what .rat does and why you can't can't just use standard images for materials and background images?
https://openfirehawk.com/ [openfirehawk.com]
Support Open Firehawk - An open source cloud rendering project for Houdini on Patreon.
This project's goal is to provide an open source framework for cloud computing for heavy FX based workflows and allows end users to pay the lowest possible price for cloud resources.
- Soothsayer
- 875 posts
It's explained in the docs:
http://www.sidefx.com/docs/houdini10.0/io/formats/image_formats [sidefx.com]
Jobless
Jobless
- pelos
- 626 posts
when Houdini render it internally make them .rat
you don't need to change them.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=17103&highlight=rat [sidefx.com]
- mark
- 2689 posts
pelos
It's still better to use them since
- The conversion is done on every render
- You don't get the benefit of paging of files
- You don't get the benefit of paging memory
For example, when rendering with a .rat file, only the parts of the image that are needed are loaded in. If the image is converted by mantra, the entire image is read and converted. In many cases this doesn't make a big difference. When dealing with very large numbers of large sized texture maps, you might notice a performance hit.
- symek
- 1390 posts
pelos
but this way, you won't see any advantage of rat files at all, since Mantra will have to load a whole file into memory in order to convert it, second it will do it every single frame (try to convert a couple of <100MB textures to see disadvantage of that scenario), So manual conversion is really good option I'm afraid, what can be pretty tedious without proper setup, like a bunch of scripts for updating *.rat directory after any texture source was changed and such…
btw some studios have a system which finds images in a scene sent to a farm, and converts&replaces textures in place. It can be tricky though… ideally some hook on mantra's side would be helpful (like arbitrary command execution on any file accessed by mantra, what would allow setup cache system among other stuff).
EDIT:ups, Mark was faster…
- probbins
- 1145 posts
- pelos
- 626 posts
“btw some studios have a system which finds images in a scene sent to a farm, and converts&replaces textures in place. It can be tricky though… ideally some hook on mantra's side would be helpful (like arbitrary command execution on any file accessed by mantra, what would allow setup cache system among other stuff).”
wow thats Cool
wow thats Cool
- Andrew Graham
- 151 posts
thanks for all the tips guys.
