Hi All,
I am relatively new to houdini. I seem to have an annoying issue with rendering. Everytime I use the Render Region tool, I get an error as follows:
IMG_TileWrite::socketWrite: No such file or directory
mantra: Error writing data to image device
I setup a a ROP with the mantra render node but still get this error. I hope this is a quick fix.
I appreciate any suggestions.
Rendering Error
4929 6 1-
- Keebler
- 6 posts
- psygoo
- 2 posts
- Keebler
- 6 posts
- Keebler
- 6 posts
Well here's a bit of an update on this issue:
It seems something in my Houdini is causing problems with the render region tool, not sure if its software, hardware, or the windows 7 os. The only way to get my renders to show up is to actually render it with a camera. I know it doesn't solve this issue but at least I can see my projects rendered, this scared me a bit because I thought I wouldn't be able to render anything.
I am navigating my way through Houdini and so far I LOVE the software. I can't wait till I get to the good stuff and for that reason you folks should be seeing me around this forum a lot more
- Fabian
- 127 posts
- psygoo
- 2 posts
A found a a solution. In my case it´s the avast anti-virus. Even if I disable, it stills running a process in memory. After uninstall it and reboot my region render work as should.
I start testing houdini in the begin of this week and I´m loving it too. Node base 3D makes more sense to me because I´m already used to eyeon fusion node base compositor.
regards,
psygoo
regards,
psygoo
- edward
- 8081 posts
Thanks for the heads up, Psygoo! I've updated the community wiki on this:
http://odforce.net/wiki/index.php/IncompatibleSoftware [odforce.net]
