Point a vector along curve direction
   24166   14   4
How would I point the normal vector of curve-points in the curve direction?
(So that they flow along it rather than all show in one direction)
Like the left three vectors in the picture below:
Jobless
try polyframe SOP
entity : Points
style : Two Edges
tangent name : N
make frame orthogonal : off
other fields empty
Or…
In point SOP / Force tab, add edge force.
This Will give you a edge_dir attribute pointing along the curve.
Poly Frame with the options above generate tangent vectors at the points.
Use the Point SOP to build vectors that point at the next point:
Point SOP > Force Folder > Add Edge Force
This adds two attributes. Look at edge_dir. It generates normalized vectors that orient to the next point.
If you use the PolyFrame with Style set to First edge it should give you the same result as adding an Edge Force.
Thanks for the many tips.
Jobless
hi guys .. thanks for all the tips … i have however tried the pointfunction in point sop:
point(“../”+opinput(“.”,0),$PT+1,“P”,0)-$TX … so on and so forth …..
i tried the other 2 methods too and have few doubts. With polyframe the direction of normals is reverse than as what i get using point function.. and somehow don't understand the edgeforce method.
have attached the file … maybe someone could check and explain pls.
thanks
Normals_directions.hip (79.5 KB)
added edge example
normals_directions_fix.hipnc (82.4 KB)
thanks swann… that works .. however i was hoping if you could reverse the normal direction on polyframe
thks
Append a Reverse SOP before the PolyFrame and you'll get the result you want.
ohhh great.. thanks for your help graham.
As this is a very interesting thread I wondered if I could push it further. I wanted to create a tool that could aim a custom vector using the handle from the line sop to control the direction. I am unable to even via a vop sop control the direction of my custom vector. Can someone give some pointers on the handle aspect and where I am going wrong with my vector.
Rob
I have updated the file with another example this time I have been able rotate the vector. In the details view you can see the aim attributes values.
Edited by - Feb. 9, 2010 20:47:28
vectorAim.hip (130.4 KB)
Gone fishing
I have a related question:
How could I point the normal of a particle in its direction of travel?
Edit: Sorry, I figured it out the second I hit the post button…argh…velocity…
Jobless
Something like this?
I just use a Point SOP and promote the N control in my case and then create a Vector handle and bind the N parms on the asset to it.
vector_pointer.hipnc (50.4 KB)
Graham… Cheers
My contribution. A small tool that can aim a custom vector. I've found it very useful indeed
rob
rse_sop_vector_aimer_v001.otl (18.8 KB)
Gone fishing
