How can i stick a circled obj to the grid to edit or reshape it by moving its points only horizontally. Thank you very much.
Steve
sticking circle to grid
3679 8 2- aplink
- 365 posts
- midorime
- 31 posts
- aplink
- 365 posts
- midorime
- 31 posts
- aplink
- 365 posts
Thank you very much again.
Yes, i did added,
I textured and animated a butterfly wing and realized that i should have started using curve with CVs method instead of " Freehand "
And, now, i want to reshape the wing using CVs Method. But, the wing is already textured & animated and i can not stick the wing to the grid to reshape it. I've attached the dummy file for your review.
That's the problem. Can you help me please ?
Steve
Yes, i did added,
Steve
Edited by - Feb. 19, 2010 01:30:09
- aplink
- 365 posts
- midorime
- 31 posts
Hi Steve,
I saw your last file… be careful with the warnings you have in the capture nodes and somewhere else, you should try to solve them.
About your idea to reshape the fly with a grid… I used a Project SOP…
Take a look to the scene I attached and let me know if is that what you are trying to achieve.
For the CHOPs and music… well… one step at time…
start with study the guide to see what kind of nodes the CHOP context gives to you and then if you like maybe you could be interested in http://www.sidefx.com/index.php?option=com_content&task=view&id=1268&Itemid=66 [sidefx.com]
I remember there was another simpler example online but at the moment I don't remember where… so, try to look around and see what other people have already done.
When I will found the link to the tutorial I saw, I'll post you.
Good luck with your project,
Emanuele
Emanuele
- aplink
- 365 posts
- aplink
- 365 posts
Thank you very much !
It's working now.
I appreciate your tremendous help.
(For the CHOPs and music… well… one step at time…
start with study the guide to see what kind of nodes the CHOP context gives to you and then if you like maybe you could be interested in http://www.sidefx.com/index.php?option=com_content&task=view&id=1268&Itemid=66 [sidefx.com] Steve)
I bought it already and studied a lot. Very hard, still need a lots of help.
Thanks anyway.
Steve
It's working now.
Thanks anyway.
Steve
