hi!
Maybe i'm missing some logic here:
-i have a mantra1 ROP and a wedge rop
-i have say 3 takes take1 take2 take3 under a parent take called passes
-on main take the mantra1 ROP's frame range is set to 1-100
-on each take i override the frame range so take1 is 1-25, take2 is 25-50 and take 3 is 50-100, just arbitrary numbers.
- the wedge method is set to take and the output driver is mantra1
Now here comes the problem, when writing out ifds with wedge i will get the frame range from the take which is currently selected, so the range overrides will be totally ignored.
In the example file if You are on Main take it will render that frame range 1-15, no matter what.
Is this a bug or i'm missing some logic here?
Wedge ROP question
1764 1 0- buki
- 1769 posts
- buki
- 1769 posts
any ideas?
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
