id like to trap a callback on a multiparm list when items are
added/removed/cleared etc… unlike other params, this container
doesnt have a callback field. Is there some other way to register
a callback on the container to manage it, or do you have to drive
global management whenever one of its template params are
modified?
hacks?
multiparm callback for OTL? HOM?
3518 2 1-
- sdugaro
- 380 posts
- graham
- 1914 posts
Unfortunately there isn't any way to do this. From an old email about such an RFE:
The only kind of hack I can think of off the top of my head for something similar would be to have a button that does it manually. You would have to keep track of a list of multiparm instances through a parameter name or something and when you make a change hit a button that calls code to figure out what was added/removed based on what indicator parms are left and what is stored on the list, then try and handle the change.
This is an existing RFE, (ID# 30076). However, it is a very difficult RFE for us to accomplish because it has never been possible to associate a callback with a multiparm, even in C++. There is no way to set the PRM_CALLBACK type on the PRM_Template, and no argument to the constructor for setting the callback information.
- megasets
- 85 posts
I had a similar issue
I did not want the artists to need to remember to press an update button so:
I created an integer with the callback attatched
i put a channel expression in the mutiparm block referencing my int parm
i then hid the multiparm
hey presto - the great thing is you still see all of the parms in the multiparm block!
hope that helps
hope that helps
Sam Swift-Glasman
Art Director
Five AI
Art Director
Five AI
