I used a shatter tool on a poly extruded grid, it gives me a unwanted surface along the cut. When I set ‘creat inside surface ’ off , that unwanted surface disappears but then the shattered pieces remain opened. When I disable the poly extrude sop it works fine (see sphere object1 network).
Can someone please explain?
Shatter tool - Creat inside surfsce
2932 2 1- sadhu
- 112 posts
- sadhu
- 112 posts
- sadhu
- 112 posts
It seems that I got the solution. I used primitive sop after poly extrude and befor shatter sop. In it's Face/ Hull option go to vertex and set it to ‘Reverse’ and the unwanted surface I was talking about, disappears!!
But didnt understand how it solved the problem? . (This is changing the surface normals direction)
can someone please explain this to me
