Poking through the “What's New in H11”, I read about vm_volumeuniform. So I added that property to an object in my scene and clicked render. The geometry rendered exactly the same. Tried adding the “Basic Smoke” material, and it didn't render at all.
On an unrelated note, between the odforce forums, these forums, and the sidefx mailing list, where do people feel there's the most activity these days?
Has anyone gotten vm_volumeuniform to work?
5541 7 2- rjpieke
- 65 posts
- ikerr
- 168 posts
- rjpieke
- 65 posts
- ikerr
- 168 posts
Try rendering using ray-tracing or enabling the “Raytrace Shading” option on the sphere's Render > Shading tab. Uniform volumes only work with ray-tracing and PBR, not micropolygon rendering. I was using IPR, which automatically enables ray-tracing when the ROP is set to Micropolygon mode, so I forgot to check off this flag on the sphere.
–Ian
–Ian
Ian Kerr
3D Software Developer
- rjpieke
- 65 posts
- ikerr
- 168 posts
- Korhon
- 334 posts
- ikerr
- 168 posts
The main purpose of the uniform volume is to render a volume quickly, without ray marching. To do this, it assumes that the volume has a uniform density. If you want the density to vary throughout the volume, you'll need to use a traditional, voxel-based volume.
Regards,
–Ian
Regards,
–Ian
Ian Kerr
