Hi all,
I'm trying to use a COP network to drive the length map of a fur object.
The cop net is animated (a shape changing scale).
The length map seems to work fine at the first frame, but when I play the animation,
the it behaves quite strangely.
Am I doing something wrong? or am I missing something ?
thanks in advance
j.
COP and fur length
3710 4 0- john_z
- 45 posts
- blonde
- 53 posts
- john_z
- 45 posts
Thank you for your reply.
Maybe the crash is due to a different release.
However the scene setup is very simple.
Create a grid, attach fur.
Create a cop network with a shape node (circle) and animate scale or/and translation.
In the fur node set the length map parameter to:
opobj/cop2net1/shape1
The first frame should work fine, but playing the animation it doesn't.
- blonde
- 53 posts
Here it's working,
i suppose you have put an uv node in your grid before create fur on it,
then seems a visualization problem, i've turn off main fur display and used Hair Guide with scattered off.
Anyway in Mantra it render good.And before keyframing the value of a ramp i can visualize correctly moving the slider of the Phase, after the keys it has strange flickering behaviour.
Whether 'tis nobler in the mind to suffer
The slings and arrows of outrageous fortune,
Or to take arms against a sea of troubles,
And by opposing end them?
- john_z
- 45 posts
