RealFlow Plugin issue
   4761   2   2
I'm struggling to get the RealFlow plugin toolbar to function correctly.
Whenever I click any of the plugin buttons in the RFRK toolbar, I'm greeted with a huge error message and log as attached. I've also pasted the error log (from the ‘show details’ section, at the bottom of this post).
I feel so close now, as I couldn't initially find the RFRK toolbar, but after creating a symlink, it's now installed in my UI. I just can't get round this error message yet.
Any help on this would be massively appreciated.
Thanks in advance.
Error log (from ‘show details’ section):
File “object_rf_flowparticler”, line 3, in <module>
File “/Users/prisms/builder-new/Nightly11.0/dev/hfs/houdini/python2.6libs/toolutils.py”, line 756, in new_func
return function(*args, **kwargs)
File “/Users/prisms/builder-new/Nightly11.0/dev/hfs/houdini/python2.6libs/objecttoolutils.py”, line 138, in genericTool
translate_parm_name)
File “/Users/prisms/builder-new/Nightly11.0/dev/hfs/houdini/python2.6libs/objecttoolutils.py”, line 82, in genericObjNodeGeneratorTool
newnode = createObjNode(container, nodetypename, (), nodename)
File “/Users/prisms/builder-new/Nightly11.0/dev/hfs/houdini/python2.6libs/objecttoolutils.py”, line 24, in createObjNode
run_init_scripts = False)
File “/Users/prisms/builder-new/Nightly11.0/dev/hfs/houdini/python2.6libs/hou.py”, line 4211, in createNode
return _hou.Node_createNode(*args, **kwargs)
MatchDefinitionError: Failed to match node type definition.
Error: Bad node type found: rf_particle_display in /obj/rf_flowparticler1/rf_particler_geo.
Warning: Unknown channel(s) "fname1, mute1, fname2, mute2, fname3, mute3, core, splash" converted to spare parameter(s).
Warning: Skipping unrecognized parameter “stdswitcher”.
Skipping unrecognized parameter “seqnum”.
Skipping unrecognized parameter “ftype1”.
Skipping unrecognized parameter “offset1”.
Skipping unrecognized parameter “ftype2”.
Skipping unrecognized parameter “offset2”.
Skipping unrecognized parameter “ftype3”.
Skipping unrecognized parameter “offset3”.
Skipping unrecognized parameter “ftype4”.
Skipping unrecognized parameter “fname4”.
Skipping unrecognized parameter “offset4”.
Skipping unrecognized parameter “core4”.
Skipping unrecognized parameter “splash4”.
Skipping unrecognized parameter “mute4”.
Skipping unrecognized parameter “ftype5”.
Skipping unrecognized parameter “fname5”.
Skipping unrecognized parameter “offset5”.
Skipping unrecognized parameter “core5”.
Skipping unrecognized parameter “splash5”.
Skipping unrecognized parameter “mute5”.
Skipping unrecognized parameter “ftype6”.
Skipping unrecognized parameter “fname6”.
Skipping unrecognized parameter “offset6”.
Skipping unrecognized parameter “core6”.
Skipping unrecognized parameter “splash6”.
Skipping unrecognized parameter “mute6”.
Skipping unrecognized parameter “ftype7”.
Skipping unrecognized parameter “fname7”.
Skipping unrecognized parameter “offset7”.
Skipping unrecognized parameter “core7”.
Skipping unrecognized parameter “splash7”.
Skipping unrecognized parameter “mute7”.
Skipping unrecognized parameter “ftype8”.
Skipping unrecognized parameter “fname8”.
Skipping unrecognized parameter “offset8”.
Skipping unrecognized parameter “core8”.
Skipping unrecognized parameter “splash8”.
Houdini RenderKit Error Screen.jpg (194.6 KB)
No-one
Everything works without a hitch in Maya, but no joy in Houdini. Shame, because it's my fluid sim software of choice.
Make sure you are running the exact version of Houdini that the RealFlow plugin is built for. Can't help more than that because no access to RealFlow myself.
Drive, monkey, drive!
