Python - create rendering parameters
11031 7 1- Soothsayer
- 861 posts
- graham
- 1908 posts
Rendering parameters are just like any other parameter but named in such a way as having meaning to Mantra so, you can add them manually using Python. There's no Python interface for easily adding rendering parameters but if you know the settings you can easily add various ones.
You can always add your parameter to a node and use asCode() to get the creation commands for it.
- Soothsayer
- 861 posts
- Stalkerx777
- 183 posts
Hi.
Here is a simple example from documentation
>>> node = hou.node(“/obj”).createNode(“geo”)
>>> group = node.parmTemplateGroup()
>>> folder = hou.FolderParmTemplate(“folder”, “My Parms”)
>>> folder.addParmTemplate(hou.FloatParmTemplate(“myparm”, “My Parm”, 1))
>>> group.append(folder)
>>> node.setParmTemplateGroup(group)
Aleksei Rusev
Sr. Graphics Tools Engineer @ Nvidia
- Soothsayer
- 861 posts
- Soothsayer
- 861 posts
Oh on follow-up question to this.
How to I find sub-tabs?
For example on my node I have “Mytab” as a subtab of “Material”. Now, I can find Material like so:
hou.node('/obj/mynode').parmTemplateGroup().findFolder(“Material”)
but
hou.node('/obj/mynode').parmTemplateGroup().findFolder(“Mytab”)
does not work.
I tried variations of this (like Material/Mytab) but there seems to be no easy way of getting it?
but
does not work.
Jobless
Jobless
- Soothsayer
- 861 posts
Well, I found a way to do it by looping through parmTemplates but it appears to be useless because for some reason the parameter is not picked up by the renderer. It only works when I use the local material parameter overrides, which is kind of strange because the parameter has the same name…
Jobless
Jobless
- Amit Khanna
- 14 posts
Hi guys,
I am adding a rendering parm to a ROP using the code provided here. But when I add this parm, some of my settings on Image Planes are reverted to default. For example Light Exports are set back to “No Light Exports” also if I have Override Camera Resolution checked, then Resolution Scale is also set to 1/10…
Any idea what might be happening?
Thanks,
ak
Thanks,
ak
