Hello all,
is there a way to change the size of the brush when using the selection paint tool?
And (perhaps more important) is it possible to turn off the display of the normals while selecting?
Thanks,
Koen
size of the pick brush
6895 8 1-
- koen
- 795 posts
- goldfarb
- 3465 posts
- koen
- 795 posts
- Stalkerx777
- 183 posts
- koen
- 795 posts
wow, thanks for pointing that out, I should look in the obvious places first I guess :-)
Then, maybe another simple one. I use the paint selection mostly on primitives. However, this does not really work, since even when selecting primitives, the selection is determined by the points you cross, not the edges or faces. This way it is really hard to select one column of faces, and what gets selected feels broken.
Is there a way to fix that as well?
Koen
Koen
- goldfarb
- 3465 posts
- malexander
- 5285 posts
This is being addressed in H12. Painting will also only capture visible faces by default, as well (as will other area-select operations).
- nicholasralabate
- 162 posts
- jsmack
- 8177 posts
