extending nodes with python
   1586   1   0
what is the best practice to extend a node for example adding a tab with custom parms
1) For HDAs, I can do this via the type properties dialog. Extending the mantra node for example, changes are of course saved on the local OPlibdriver and not on a central $HSITE. I do not want to copy it there because every time the mantra node gets an update I would have to redo everyting. And this only works for HDAs. Or is there a way addon to a HDA.
2) On a sphere node I cannot edit operator types, but the Parameter Interface. but how is this saved?
3) monkey patch hou.Node.createNode with something like:
def customCreateNode(*args, **kwargs):
# create node then do something with it like attaching new parms
pass
hou.Node.createNode = customCreateNode
This is how it works in Nuke but its giving me errors I have to investigate…
4) regular callback (I could not find in the docs)
5) Other solution?
Cheers
Sebastian
