Points Inside Volume
14029
6
1
Gerlandox
Dec. 4, 2011 12:13 p.m.
Hey guys I suppose the subject says it all. I want to select points with a volume say a grids point with a sphere.
“And those who were seen dancing were thought to be insane by those who could not hear the music.”
graham
Dec. 4, 2011 12:29 p.m.
Gerlandox
Dec. 4, 2011 12:46 p.m.
Yup that does it thank you. Is there any other way to feed to it the geometry shape in case you dont want to use the bounding of the GroupSOP?
Gerlandox
Dec. 8, 2011 9:13 a.m.
Sorry hasty question!
ragupasta
Dec. 9, 2011 4:10 a.m.
Not sure what you mean. You want to use the surface geometry to group points by? If so that IS done inside the bounding tab of the groupsop. You just specify a shape to use by wiring your geometry into the second input.
teapot.mov (2.1 MB)
selection_by_geometry_001.hipnc (63.4 KB)
Gerlandox
Dec. 21, 2011 5:20 p.m.
yes I figured, it does not make sense in the houdini mindset.
But thank you for the hips anyways.
Gerlandox
Dec. 21, 2011 5:22 p.m.
