[solved] how to color particles using infr-red color scheme?
3073 5 1- oat
- 479 posts
- zarti
- 330 posts
hi ,
here im uploading a file which might be useful ; with the VopSOP you can have more control over the colours .
im posting also the simple python otl which i used in the file , since i do not know yet how to include it in the ‘scene’ .
except the things that cannot be seen , nothing is like it seems .
- oat
- 479 posts
- zarti
- 330 posts
hi Ji ,
on a side note ;
in the example i posted above , the range of color ramp fits within the whole range of “DF” attribute .
normally , applying colors in this way , isn't correct ( my example simply used min and max of DF values to define the range ) . this might be more noticeable if you had a sequence of animated .CSV files and min or max values wd change , i imagine .
anyway , you can delete imported min and max of detail attributes that are inside the VopSOP and replace the both Minimum & Maximum Value in Source with parameters to be promoted one level up . from there you can use your custom ( exact ) values to precisely ( min&max independent ) spread the colors .
again , interesting usage
on a side note ;
- oat
- 479 posts
- zarti
- 330 posts
