Split blendshapw with falloff
2998 4 1- thexon
- 86 posts
Im making full face blend shapes using edit sops,i now want to split them into…brow and mouth areas,is there Ny way of doing this,with falloff…..for example,if i have,a smiley face,and i want to separate the eye squint from the lips smile,i want a way that will have a sort of smooth falloff,coz groups is too harsh
the xon can
- thexon
- 86 posts
- phrenzy84
- 249 posts
- thexon
- 86 posts
Im using a paint sop,a vopsop to change the color(vecttor)into a float(luminosity)……a create attribute sop creates a new attribute by subtracting lumosity from 1…. A point sop has two inputs …(.the default shape and the deformed shape..)….an expresion uses the two attributes to weight which points are moved …i will upload a picture once i get home….i suspect your method is similar
the xon can
- phrenzy84
- 249 posts
