VOP POP, help creating a point cloud from a texture
   3922   3   0
hello,
i am trying to create a particle cloud from a texture, and have it move around later on using advect fields
however the particles generated, they start to move when i play the scene, even though i have no forces applied, the strangest thing is that they seem to have a goal based on and invisible wall, and i cannot figure this out.
i added the scene if anyone wants to check
any ideas are welcome.
Cheers
E
Edited by - Jan. 16, 2012 09:54:01
Particle_Effect_tests.hip (347.5 KB)
You're reading the position of the points each frame, subtracting from the Z coordinate and then writing that as the new position. In SOP-land that would result in just a static displacement, but here in DOP-land we are simulating the positions, and so it ends up moving the particles.
The “wall” comes from the Fit node.
Hi thanks for the info,
forgot to mention i am a fairly new user, so i understand what would happend tih that in a DOP network, and also what is going on with the fit node,
but i do not get why is it simulating movement in the particles when the texture source doesnt change.
are you saying that i should change the setup, to have the particles beeing positioned in that fashion with no regards to actual particle position, in order to bypass the per frame calculations?
#################EDIT###################
found a way around it stoppping the activation of the node.
thanks
You could also do static phases of the setup in SOPs before you even enter the POP simulation. Some stuff is easier to grasp in SOP-land, plus it can be faster, as the DOP stuff gets run each frame.
A simplified example attached.
particle_setup.hip (109.6 KB)
