Cinema 4D like tracer object?
   5378   3   0
Hi everyone,
I'm trying to build something similar to Cinema 4Ds tracer object. In case you don't know it, it basically, among other things, connects all objects of a group with splines, so you end up with a web-like object that connects all elements of that group. How would I go about setting something like this up in Houdini?
Pardon my ignorance and thanks in advance for any hints…
hi ripclaw ,
you can use the Add SOP ..
mind you , it connects points , not objects ( from OBJ context ).
( look at the red node in the attached file )
if you are referring to items in OBJ context , i think a python SOP wd collect necessary info and build the needed points to feed later into the Add SOP .
hope this helps .
.cheers
untitled_addz.hipnc (42.5 KB)
except the things that cannot be seen , nothing is like it seems .
Hi ripclaw,
here are two options to do it with geo nodes without using python.
Sorry, but I don't have much time to comment the file properly. If you have questions about it feel free to ask
-dennis
tracer.hip (97.9 KB)
Technical Reel 2015 [vimeo.com]
Hi guys,
thanks for your suggestions, they gave me some good ideas. I had tried with adding a point at the centroid location already, the main issue was the connecting of each object to each other. I guess I won't get around doing this through some sort of Python script (the problem is that one primitive not only should be connected to the next, but to all other primitives)
Michael
