HOUDINI_TEMP_DIR and Dopnet Caches
9733 5 0- Solitude
- 373 posts
Houdini 12 I'm running a sim with cache to disk on. I have my HOUDINI_TEMP_DIR variable set to /scratch2/tmp my system $TMPDIR is set to /scratch2/tmp as well. When doing a sim, my /tmp folder is filling up with hfs*.tmp files which are rather large. My fix will be to just symlink the /tmp folder, but I'm wondering if the dopnet should respect the HOUDINI_TEMP_DIR variable or not since doesn't seem to be doing that for me. I haven't tested this in 11 yet… but my horrible memory is telling me that it worked ok in 11.
Ian Farnsworth
- kare
- 30 posts
- Solitude
- 373 posts
EDIT: Ok, in the open dialog It looks like houdini has $TEMP looking at /tmp, but when I open hscript textport returns /scratch2/tmp – if i do a setenv TEMP = “/scratch2/tmp” then the open dialog shows $TEMP pointing to /scratch2/tmp as expected… wierd. I'll have to look into where I'm setting it in the first place.
Ian Farnsworth
- kare
- 30 posts
if you are using bash shell in linux
../houdiniVersion/houdini_setup_bash
edit “export TEMP=/tmp” houdini_setup_bash to your destination directory..
similary in if you are using chs shell in linux
../houdiniVersion/houdini_setup_csh
edit “setenv TEMP /tmp” houdini_setup_csh to your destination directory..
cheers..
cheers..
@@KaRe@@
- vtwinracersp2
- 30 posts
so i was able to set HOUDINI_TEMP_DIR to point to something else besides /tmp
seems like houdini is putting some temp files into my new tmp directory.
problem is, houdini still keeps putting vop_VEX into /tmp ( /tmp/vop_VEX )
seems like it's also still writing hfs*.tmp files to /tmp also.
i'm just doing a simple test. created a simple pyro fx setup from the automatic pyro shelf tool.
any ideas?
any ideas?
- vtwinracersp2
- 30 posts
seems like you have to put it in your ~/.profile (if you are using bash that would be .bash_profile)
export HOUDINI_TEMP_DIR=<your_temp_dir>
if you are using bash and fedora, it helped to log out of x windows and log back in for the shell to pick this change up. i just thought opening up a new shell would pick those changes up, but no it doesn't.
