Hi all,
I need to transfer material from one subnet to another subnet
for example
I have Subnet A and Subnet B
inside of Subnet A i have sphere geo named A
and inside of Subnet B also i have sphere geo named A
i used this python script to transfer material
import hou
def getNodeList(Node_A,Node_B):
getObjectsInSubnet_A=hou.node(“/obj/”+Node_A)
getObjectsInSubnet_B=hou.node(“/obj/”+Node_B)
for child in getObjectsInSubnet_A.children():
t=child.name()
for allObjects in t:
allShopPath=hou.parm(“/obj/”+Node_A+“/”+allObjects+“/shop_materialpath”).eval()
print allShopPath
getObjectsInSubnet_B.setParms({“/obj/”+Node_B+“/”+allObjects+“/shop_materialpath”:allShopPath})
and it is working fine and my issue if i rename both sphere geo to AA(or more than one letter)
its not working giving this error
File “<console>”, line 1, in <module>
File “D:\Sab_VFX\RnD\Houdini\RnD\python\hou_script\getNodeList.py”, line 10, in getNo
deList
AttributeError: ‘NoneType’ object has no attribute ‘eval’
How to sort this or any problem with python script
or any other method is there
Material Transfer Script issue
3708 3 1- sabareeshrg
- 33 posts
- zarti
- 330 posts
sabareeshrg
maybe you can get the Node and use evalParm() instead of parm( .. ).eval()
http://www.sidefx.com/docs/houdini11.1/hom/hou/Node#evalParm [sidefx.com]
except the things that cannot be seen , nothing is like it seems .
- sabareeshrg
- 33 posts
hi Guys found a way adjusted script litle
import hou
def materialTransfer(getNode_A,getNode_B):
subNetA=hou.node(“/obj/”+getNode_A)
subNetB=hou.node(“/obj/”+getNode_B)
for allNodes in subNetB.children():
getAllNodes=allNodes.name()
#print getAllNodes
allShopPath=hou.parm(“/obj/”+getNode_A+“/”+getAllNodes+“/shop_materialpath”).eval()
subNetB.setParms({“/obj/”+getNode_B+“/”+getAllNodes+“/shop_materialpath”:allShopPath})
print (“Material Transfered succesfully without any Head ache”)
but its taking too much time cook materials
import hou
#print getAllNodes
sab
- sabareeshrg
- 33 posts
thanks Zarti
let me now its woking let me see evalParm()
thanks Zarti
sab
