hi all
i am trying to learn houdini and as such want to recreate the level that was created at the bottom of the page in the video here
http//www.sidefx.com/index.php?option=com_content&task=view&id=2139&Itemid=68
i have 2 curves going into separate sweep nodes, all working
the problem i am having is the next step of projecting the curve onto the surface and offsetting it to create the paths (
If anyone could show me a tutorial or step by step i would be massively appreciative
Thanks in advance
profile SOP
2694 5 0- broomy
- 8 posts
- zarti
- 330 posts
broomy
hi and welcome ,
do you mind posting at least a screenshot of your network ?
or a sketch of what you want to achieve .. ?
usually a tiny illustrative hip file works best .
except the things that cannot be seen , nothing is like it seems .
- broomy
- 8 posts
hi and thanks )
i have attached my hip file for you, the project1_ThatDoesentSeemToWork node is the one that should as far as im aware have geometry resting on its surface from the pathGeo_Sweep and extracted using the profile.
Thats step one, then i need to offset/push/sculpt the underlying geo down to create a groove
I have also attached a viaual example of what im attempting
Thanks again
Thanks again
- zarti
- 330 posts
i wdnt suggest to proceed with NURBs on that point , because those are ‘unpredictable’ , ime .
use polygons instead at any resolution you like .
in my file there are two outputs : yellow nodes put path polygons into a special group , while the red nodes separate path from the terrain as geometry .
hope this helps ..
hope this helps ..
- broomy
- 8 posts
- broomy
- 8 posts
ok i think i understand a bit better now thanks for the help.
Unfortunately whenever i try to use polygons i get a crash, specifically to test it out im creating a grid and a tube, when i try to select the faces (primitives ?) of the tube to add them to an extrude or group i get a crash every time, must have tried it 20 times now. Bug in houdini/apprentice or am i doing something wrong?
cheers )
cheers )
