smoke-object-color
   2966   4   1
I have a smoke simulation.the smoke interacts with a static object and I want the static obj to change its color when the smoke interacts with it.
how can i proceed?
Try a Sop solver with an attribute from volume sop.
(or if the color change is not “permanent”) just an attribute from volume sop.
Koen
could you look at my file.My friend told me to use volume sample from something.i am beginning with volumes.so i dont have proper knowledge.
could you correct me where i gone wrong??? thank you
tosesi.hipnc (979.6 KB)
volume sample from file is the vop node that you can use to get the grid values. in H12 there is a new sop node, attribute from volume that is a simpler solution in this case.
Here is an example, mostly build with the shelf tools.
Hope that helps,
koen
color by sim.hipnc (1.3 MB)
Hi Koen,
thanks a lot
